10 bolt or 12 bolt
Got 522 big block in 74 nova broke my 10 bolt axle (8.5) it has a spool in it. Go back with a 10 bolt or 12 bolt. Got 600 hp and 200 shot nos
Since you're alredy set up with the 10 bolt 8.5, i'd just buy some good axles, the big 10 is not that weak.
JMO Zip. |
X2
One of our Own ( Rudy Holloway) had a complete braced 9 inch rear with brackets and all ( except brakes).......he woud make you a good deal i am sure if he still has it..
only question is what width would work for you. you might wanna look around a little before you spend that money for those axles...people are getting rid of some pretty good stuff right now..would be a shame for you to invest that $ 300 or so in those 10 bolt axles when you could have spent a little more and stepped up to a nice 12 bolt or 9 inch............Just my two cents.. |
10 bolt or 12 bolt
would like 9" or good used parts need a good rear end i live in south ga.
10 bolt or 12 bolt
rear
your rearend is it stock springs, ladder bar, what with, might have one for you. 12 bolt that is,,,thanks
Re: 10 bolt or 12 bolt
Brian,
Thanks for the heads up my friend! The 9" I had is gone, purchased by a local bracket racer. |
Re: rear
| All times are GMT -8. The time now is 11:49 AM. |
