sbc aluminum head suggestions????
I'm in search of a set of good heads to put on a 355 street engine going in a 4x4 truck? It will be driven everyday. My local shop is pushing a set of procomps but ???? need suggestions thanks
AFR 195 heads work great.
Re: sbc aluminum head suggestions????
sbc alum heads
I had a set of both Pro Com alum heads and still have a set of 180/68cc AFR street heads. There is no comparison in the quality, but AFR's are going for almost 1500 new. The people who bought the Pro Comp heads (still on engine) are happy with them but they are not die hard top level racers. On a street motor the Pro Comps should work ok but will not flow even close the name brand heads out of the box. JMO Zip and Hink, what do you think? Mep
dart
Re: sbc alum heads
JMO Zip. |
brodix track I heads. Lots of potential
Mine flowed 322 at .750 lift |
afr 195s all the way
i don't understand all the bad rap about procomp heads.i have had 2 sets with no problems. sure they are not the best,but what other head can you get for 650.00 (skip white)and run pretty strong....never buy them direct. i get them from a local speed shop,bare. he puts manley valves,comp springs and 10 degree locks on them. a set of 210,cnc with roller springs go for 1000.00...the new castings,claim to take care of any cracking problems....he did a test with them on his 3200 lbs nova,406 sbc....best with 227 cnc, afr heads was 10.00-1/4 mile....then put the procomps on with the same comb. chamber..the car went 9.90. they can't be that bad...on the other hand,i would'nt put there rocker arms on a lawn mower.fuel pumps either.
| All times are GMT -8. The time now is 01:14 PM. |
