hp est
just would like a close est? bbc 454 bored and stroked to 496. je 13to 1 comp pistons doug hubert solid roller cam 714/714 dart iron heads 308 with 2.25 int and 1.88ext holley strip dom intake with 850 modified carb and all msd ignition straight headers and all electric components, water, fan thanks for all estimates :?:
I'm assuming with 13:1 comp it's not a street engine. I think the heads and carb are really gonna hold it back. But if i had to guess i'd say 625-650.
street
no i have it in a "street stock" pulling truck spossed to have oem heads tring not to make it noticable thanks though
Heres my swing at the pitch
572 pk HP @ 5000 681 pk TQ @ 3500 Nice combo shit loads of torque @ 5000 rpm still has 600 ft lb tq |
thanks it in a pulling truck that is great if have that much torque that low shouldn't puke at the end
anyone else out there with est? just wondering how you all get the numbers?
TQ is the advantage of running the smaller head..i also run a smaller valve head on a 565ci in my camaro (with a lot of Runner work),,,cause its a Heavy pig i run in the 1/8..so i wanted it to be a little more Tq'y.
i think Slickfuel is all over it,,could be a tad more HP..But not enough to beg the differ... ok i will say 573 hp...same Tq as what Slick fuel says....LMAO THE OLD PRICE IS RIGHT TRICK ! |
Right around 600hp...the heads are limitin you with that cam...go to an aluminum head that breaths better like Dart Pro !'s say 325's goes to around 700hp, 355's around 750hp....
thanks guys anyone else?
| All times are GMT -8. The time now is 04:19 PM. |
