hurest quarter stick electric shifter
Have a hurst electric shiftnoid that has three wires coming from it. Newer versions only have two. Question is where do the wires go?? Hurst doesn't have a clue. Got a good idea but need to be sure. Anybody running one of these? Thanks
WTF?? A solenoid should just has a hot and a ground. :? Ground curcuit broken by a relay is how mine works...spring shoves the shifter fwd
shifter
The current version has the two wires and is easy to wire up. This one has three(red,black and white). tried wiring it several ways but none seem to work right. Guess i.ll buy a different one. Thanks
I will sumize the red is battery hot, the black is battery ground and the white is hooked to the trigger wire from the rpm activated switch.
Just a thought>Cp |
| All times are GMT -8. The time now is 09:20 PM. |
