-   -   which comp cam is best? (https://www.racingjunk.com/forums/showthread.php?t=23483)
jim1967 03-16-2009 04:38 PM
I am about to re-build my 289 2 barrel with a 4 barrel and have narrowed the cam down to the comp cam xe262h or xe268h and am trying to get some feed back on the performance. I have a c4 and will change my converter to a 2000 stall and have a 3.4 posi rear end. i am not sure what the current compression is but feel it is stock as the engine was re-built to .030. I would like to hear from someone who has either of these cams.
cepx111 03-16-2009 07:26 PM
When I was about 22 I had a 63 falcon futura that had a 64 fairlane 289 2 barrel and C4 in it when I bought it, I freshened up the motor, slapped a performer intake and Holley 600 double pumper carb and a HI Energy 268 cam, oh boy talk about waking a sleeping giant up. That car was scary fast. It had 323 gears and would not spin a tire, I ran off and left most everybody at the light, if I remember correctly it ran low 13's in the 1/4 with no other mods and a old point type dist.
Just make sure to upgrade to the stiffer valve springs though.
Cp
radicalz 03-16-2009 07:42 PM
:D :D Cp is right does not take much to make that engine a screeeeamer......268h and some good valve springs intake and headers....then hang on :wink: :wink:
