-   -   cracked oil pan??? (https://www.racingjunk.com/forums/showthread.php?t=23467)
rooski 03-15-2009 07:57 AM
cracked oil pan???
I've got a bbc 454 roller mtr, street strip approx 550hp developes cracks in oil pan after a few months. last pan was a moroso heavy duty 7 qt. what could be causing this?
thanks
Rooski
bjuice 03-15-2009 01:14 PM
{{{{{{{{VIBRATION}}}}}}}}}}.
Might want to check your damper and Flex Plate.then rotating assembly (if all else fails)..just my 2 cents
at least thats where i would start.
by the way where is it cracking ?
supergass 03-20-2009 05:39 AM
Before you go away thinking you have a engine problem, I have had nothing but cracking problems for years out of the Moroso pans. Many others I have tig welded up as well. I started using the Hamburgers econo pan, it is thicker and stronger and works great.
TheYellaBrick 03-22-2009 09:30 PM
Does the goldish anodizing create a metallurgy issue on Moroso's ?
