-   -   can somebody help me with an oil filter ??? (https://www.racingjunk.com/forums/showthread.php?t=23418)
bobby36 03-11-2009 04:54 PM
i have a 358 in a s10 i have to pull the headers off to change oil filter can anybody tell me if i can put the oil filter on the fender well or somewhere else
bjuice 03-11-2009 05:00 PM
yes you can mount a remote Filter anywhere you wish..Jegs,Sumit,Ron Owens or any parts dealer sells them
TheYellaBrick 03-11-2009 05:21 PM
Just don't screw on a FRAM.........
Read why below
http://forums.racingjunk.com/viewtop...t=fram+filters
signsbyesa 03-11-2009 07:12 PM
yea, remote should fix your problem and don't give yourself
another problem and use a FRAM, good luck bud :wink:
jmarksdragster 03-11-2009 07:42 PM
Good advice, no Fram filters. Wix/NAPA is the best to use.
Scooterz 03-12-2009 12:43 PM
X2....make sure that if you install the remote system, you use different lines if it will be near any heat source. Depending on the location & how you route the lines, the kit lines given are JUNK. I relaced mine with 8AN lines due to close proximity of the headers. And yes, skip FRAM Good luck!
us7race 03-13-2009 12:48 AM
I done the same thing to mine when I ran full length headers, it was still a pain for starter issue's and It is kinda a pain to get the oil lines to clear the flywheel too.. So now I run fenderwell headers and am much happier.
bobby36 03-15-2009 07:03 AM
thanks guys yall have been a big help this hole job has been a pain in the.........you get the picture......that is one bad s10 pull n them wheels i believe mine would do that if i could just hook it a little better..any advice on that one i have leaf springs some kinda taction bars that go from rearend to the frame under the cab...456 gears 5000 stall 630hp 1.5 60ft 7.17 et 93 mph spins a little taking off have 28tall 10.5 m/t around 3k pounds guesing
TheYellaBrick 03-16-2009 10:10 AM
Wheels up is great for show but slower as it robs forward momentum.AND it can be inconsistant as all getout as well as the danger factor of being out of control ! Unless ya have steering brakes :shock:
radicalz 03-16-2009 07:57 PM
Jody damn boy that truck leaves hard...... :wink: :wink:
