Anybody done this, and
what was the solution???
O'k i've got a Dart lil "M" 350 mains, 434" question i want to use a Milodon diamond scraper pt# mil-32250. Milodon tells me that the stud kits listed at the mail order houses pt# 81150 will not work with this scraper because of the taller main caps. ARP does not show a stud kit for this application. Has anyone done this and what studs did you use. Maybe Dart sells a stud kit i haven't talked too them yet. Zip. |
We get have gotten alot of calls about this issue with the SHP blocks and some time in the near future ARP is going to offer a stud kit for windage tray.
Any studs you use in the block should the ones for small jounal block as the Darts take shorter hardware then the OEM blocks. |
Thanks Carl,
Right now i have the OEM bolts that came with the block, and the windage tray was an after thought, because i'm sure it's good for a few HP. Zip. |
Zip,Why not weld some mounts in the pan and bolt the screen to them? Bill.
| All times are GMT -8. The time now is 11:59 PM. |
