Enderle injection . nozzles and pills
I need your guys thoughts again. I am just about to run up my 632 BBC that i have been building for the last 6 months. I need to know what size injector nozzles and pills to run for first start up on the dyno. I can tune it from there.
Stats are: 632 Big Block chev , 14-1 CR , Mild port BB3 Xtra heads. Enderle bird catcher on edelbrock victor 2R Ram. 800-800 lift 114 lobe seperation 4-7 swap cam. Let me know what else you guys need. Its in a 2800lbs super stock. 1.80 2 speed glide with 4.86 rear end. any help much appreciated |
Phone Jim at Enderle... he can get you started... Also I think you have way too much gear for that motor..
what do you mean by gear
what gearing would you suggest
Wasn't my question but not more than 4.30 if you're running 1/4 mile, maybe best for 1/8 mi also due to the torque that motor will put out.
JMO Zip. |
sorry for the delay. But I have to agree about using 4.30 maybe even a 4.10 gear for the 1/4...A motor like thant will have a bunch of low end power and then add alcohol to that and the torque curve comes down even more .
another guy for fuel injection help who is in your part of the world is Ken Lowe out of Austrailia www.kenlowe.com.au |
yeap zipper, I agree 4:30's. I ran eight different sets of gears in my car, and 4:30 gave me my best times on a tall tire. 4:88 topped out before i got to the end of the track.
| All times are GMT -8. The time now is 06:25 PM. |
