Enderle injection pills???????
I need your guys thoughts again. I am just about to run up my 632 BBC that i have been building for the last 6 months. I need to know what size injector nozzles and pills to run for first start up on the dyno. I can tune it from there.
Stats are: 632 Big Block chev , 14-1 CR , Mild port BB3 Xtra heads. Enderle bird catcher on edelbrock victor 2R Ram. 800-800 lift 114 lobe seperation 4-7 swap cam. Let me know what else you guys need. Its in a 2800lbs super stock. 1.80 2 speed glide with 4.86 rear end. any help much appreciated |
I had that close to that same combo last year.
36 nozzles and 100 pill with a 80a-1 pump. If you are looking for some real good info, look at the calculator on spud millers website. http://www.fuelinjectionenterprises.com/ The best suggestion I can give you is to have the system flowed. That way you can see if you need a high speed or lean out. Call Dave Koehler at Koehler injection, http://www.koehlerinjection.com/ He does an awesome job and the service after the sale is awesome. I had my system flowed by him and I am so happy I did it. Well worth it. |
Spuds!
another vote for Spud Miller 8)
great service and helpful! |
Like (demented) stated, the pill size, really depends on the pump size you're running IE 80a-1 equals about 7 GPM, a (0) pump between 3 and 4 GPM, which would require a smaller pill, use Spuds chart it will get you close.
JMO Zip. |
demented
SENIOR BUILDER Joined: 30 Jun 2004 Posts: 113 Location: lake luzerne n.y. Posted: Sun Mar 08, 2009 1:15 pm Post subject: -------------------------------------------------------------------------------- I had that close to that same combo last year. 36 nozzles and 100 pill with a 80a-1 pump. If you are looking for some real good info, look at the calculator on spud millers website. http://www.fuelinjectionenterprises.com/ The best suggestion I can give you is to have the system flowed. That way you can see if you need a high speed or lean out. ashbros writes: I had a very sinilar set up and ran pretty much the same as listed above with the exception to the pill size. I ran 109's |
| All times are GMT -8. The time now is 01:36 AM. |
