-   In The Pits (https://www.racingjunk.com/forums/forumdisplay.php?f=18)
-   -   Color test (https://www.racingjunk.com/forums/showthread.php?t=23333)
fla1976 03-05-2009 11:58 AM
Color test
Why not give it a try?
Color test....These are the things we're supposed to do to remove the cholesterol around our brain & try to slow up Alzheimer. Concentrate on the color & not what it says. A great test, do it until you get 100%. Bet you can't get 100% on the first try! But I'm rootin' for ya. This is pretty neat! See how you do with the colors! Have fun! It takes an average of 5 tries to get to 100%. Follow the directions!
It's harder than it seems, as it should be! A brain waker-upper for today!
http://www.humorsphere.com/fun/8787/colortest.swf
Tod74 03-05-2009 01:00 PM
I got it in one try. Honest.
Try and take your two index fingers and touch the tips together..stay in that position but pull them apart slightly...and then try to rotate them opposite directions at the same time. It will drive you crazy cause it's physically impossible to do.
TheYellaBrick 03-05-2009 01:15 PM
1st run - 63% (helps to completely read the instructions :oops: :oops: :oops: )
2nd run - 100%
markadams 03-06-2009 02:47 AM
First try 50%. Really concentrated on the second, 100%. Now my head hurts. It was fun!
THERATTLER 03-15-2009 04:53 PM
My brain must be too far gone
FullTimeRacing 03-16-2009 05:24 PM
I got it on my 3rd try :? :? :? :? :?
THERATTLER 03-16-2009 05:47 PM
I could swear that I had it right every time ...took me 8 times and I still don't know which one I had wrong :oops:
