-   -   Suggestion on heads? (https://www.racingjunk.com/forums/showthread.php?t=23311)
Trailerpro 03-04-2009 06:50 AM
Hello all.
I am currently in the market for a new set of heads for my 351w. It has a mild cam in it (270/280, 448/472 - flat tappet) hooker comp. headers, stock ignition system for now, stock heads ('78 model 351), and a holley 650 double-pumper. As you can tell, it's still a daily driver. I'm just looking for something that will complement my setup and give me that bump in performance over the stock heads. Thanks for your suggestions!
John T.
bryanm 03-04-2009 12:45 PM
AFR makes the best stuff out there for Ford as far as I am concerned. The 165cc heads would probably work pretty good on your motor. I have not been that impressed with the Edelbrock stuff. The World Products would be a good choice if you wanted to go with an iron head.
