-   -   Methanol and CR (https://www.racingjunk.com/forums/showthread.php?t=23308)
jrthone 03-03-2009 10:54 PM
Methanol and CR
Whats the lowest comp ratio you would use for a 632 BBC on Methanol( Enderle bird on a tunnel ram). My engine builder has just built mine with 13.6-1 . Is this too low for methanol????????
Drtmod5 03-04-2009 01:48 AM
You're in good shape to use it.
suicidebomb 03-04-2009 03:35 AM
Go for it ! :)
hammertime 03-04-2009 05:26 AM
13:1 will be fine, I've ran it on 10:1 motors before and works fine all in the tune up :D
desoto30 03-04-2009 11:03 AM
X2 had 9.8-1 single 4 solid roller "learner"SBC 1.27 60ft 5.75 117 660 & 9.26 141 1/4 Oh 1690lb race weight went as well as we could have hoped with still more in the tune
zipper06 03-06-2009 09:49 PM
Alcohol, luv's compression but wiil run anywhere, you got what you got so stay with it, idealy 13.5 plus for more power, but you'll gain something.
ashbros 03-08-2009 04:42 PM
I've ran it in 8.5 /1 ratios but I sure love the crackle at 18/1
whop pa pop a pop pa pop
