Transmission is not shifting - 1993 Diesel 1 ton duelly
:? HELP!!!!! I have changed the filter, and oil and now the transmission won't shift, It was working before i change it. What could be the problem?
Also the diesal gage always reads empty even though i have diesel fuel in it. What could be the Problem. Thanks MaryAlice |
Oh noo, the dreaded ford fluid change, sometimes its best to leave them pan and filters alone, seen this many many times, unfotunatley your gonna end up yanking the tranny to get a rebuild, its a goner now.
As far as your other problem goes> it sounds like you fuel level sending unit is bad in the fuel tank. That requires pulling the tank and R'R ing the fuel level sending unit assembly. Goodluck, Cp |
| All times are GMT -8. The time now is 05:47 AM. |
