-   -   802ci sonnys (https://www.racingjunk.com/forums/showthread.php?t=23190)
signsbyesa 02-21-2009 06:49 PM
802ci sonnys
in this months hotrod mag. sonnys builds a 1,400hp bbc 802ci
monster that runs on 89 oct pump gas and sonnys makes his own
intake, crank, and cam, and it is made to run in the street :shock:
4.751 bore w/5.700 stroke carrillo 7.875 rods :wink:
ashtrak 02-22-2009 05:04 AM
Wonder what the price tag is on that motor :idea:
nofear57 02-22-2009 05:44 AM
:shock: maybe I'll put one in my motor home :lol:
signsbyesa 02-22-2009 07:19 AM
nofear, the first time you pedal the motor home, either the motor
will take off by itself or your motor home will ride a wheelie everytime
you put the metal to the pedal :D :wink:
can you imagine when you resell the motor home with that block,
"well sir, the home is worth 10k but the majority of the cost
is in the motor 50k" :wink:
Tod74 02-22-2009 07:22 AM
5.700 stroke :shock:
What is the Max RPM?.... 3800 :lol:
signsbyesa 02-22-2009 07:28 AM
in the article "the foothills around Lynchburg, Virgina, reverberated with
the howl of 1,417 naturally aspirated (no nitrous) horses @ 7,100 rpm
as 802 ci were put through their paces on 89 oct. Peak torque figures showed 1,140lb-ft. @ 5,800" what a street engine :roll: :shock:
dparker 02-22-2009 08:55 AM
I'm good with 3800 RPM if I'm making 1400 HP. Can you imagine it probably makes 400 HP at idle.
nofear57 02-22-2009 09:23 AM
www.sonnysracingengines.com check out their web sight and see all the juice 8) 800 cubes 900 cubes I'm sure 1000 is not to far away. I didn't see the street monster on there unless I missed it but not that it maters anyway. The only thing I could probably afford is a t-shirt :lol: Ya the motor home will have to live with the 440 a little longer :lol:
chevynovaman 02-23-2009 08:25 AM
ENGINE
COULD SOMEONE PLEASE MASS
PRODUCE THESE SO I CAN BUY
ONE CHEAP? LOL , WOULD LOVE
TO HAVE ONE...
