Ron's flying toilet any gains?
Changing from a alcohol carburetor to a flying toilet.
Both feed alcohol to the motor. Would I see any gain in et. Are there any known advanages over the carburetor. other than spending 500 + $. Thank you for your opion and any personal experience with the change. |
Much,Much more responsive which often results in better 60 ft times.
So yes if its set up right you should pick up wih the injection over carb. I have owned Both...a mechanical Pump is the best way to go on both although an electic pump can be used on the carb. ( done that too) My personal turns off on the injection is you either have to run a front mounted fuel cell ( for many space is an issue) or you have to transport from rear tank by an electric pump into a mini surge tank ,the mechanical pump pulls from the surge tank.. the adustment is tempermental and works on a by pass..so ya gotta get familier... the carb is gonna be much more consistant with less tunning on average. this is just my take on the issue. Brian |
Re: Ron's flying toilet any gains?
Both feed alcohol to the motor. Would I see any gain in et. Are there any known advanages over the carburetor. other than spending 500 + $. Thank you for your opion and any personal experience with the change. There is a lot of upside to both, injection is easy, fast and predictable. The downside is starting up without a primer system. Carb upside easy start up, warms up faster with a leanout. Down side is they still do move around in big air jumps unlike injection. |
Thank you
Thank you for your replies. Your information gives me a lot to think about.
Thank you |
Toilets, Terminators, Hat's and stacks all will generally out perform carbs, but do require a learning curve which everyone has stated. Once you get past that curve you'll probably never go back to a carb unless you're running gas. I've run all of them and only own one carberator and it's an 850 holly and it's going on a 406" street motor. but i do have a toilet, a set o stacks, and a hat that i use on alcohol ( sm/blk stuff). It's a lot easier to change a bypass pill than tuning a carb at the track to fit the conditions.
JMO Zip. |
X2, you all know the old saying, "Once you go stacks, you'll never go back" :!: :D :D
I been saving that one for a looong time. |
| All times are GMT -8. The time now is 01:32 AM. |
