-   -   gas in crank case (https://www.racingjunk.com/forums/showthread.php?t=23063)
rooski 02-08-2009 03:04 PM
gas in crank case
running two holley 670 center squirters on a tunnel ram bbc 454. have gas in oil, checked carb floats is their any other way
thanks Jack
toofazt4u 02-08-2009 03:19 PM
It depends on alot of varies..Compression is a big factor...I run a 572 bbc with a Holley that was modified to reach 1500 cfm on the flow bench.I can change the oil,and after a couple of runs,the oil will thin and smell of race fuel....I change it regularly...It is a sacrifice...Ya wanna go fast,Ya pay...Ya might also check the rings with a leekdown test...Good Luck!!!!! dan
toofazt4u 02-08-2009 03:21 PM
I am alson running 15:1 compression on the street...SERIOUS!!!!
fatjodycat 04-19-2009 10:32 PM
the last time i saw that was from a mechanical fuel pump leaking. Good luck
kwkracing 04-20-2009 06:36 PM
Too much carb, too much fuel pressure, Bad needle and seats, worn out engine, Electrc pump left on too long?.....
radicalz 04-20-2009 09:51 PM
...check your fuel pressure at the carbs...blowing by the needle/seat...causing the fuel to flood past the rings...next do a cylinder pressure chk...may be also getting past the rings...
