anybody done business with this company
i bought a used blower that was to be new refreshed unit..i feel i need to send and have it checked to make sure it is ok to use and it needs repolished bad..i talked to this company and also got a blower intake from them..he says he would disassembl my blower and make sure everything is good and right in it and repolish to a show polish job on it for only $400.00 but i can't find anything on him on net..checking to see if anyone in southern ca. area that may know or heard anything about him..he is located around or in whittier ca. company name is Nu-Tech Hi Performance also called Nutech Racing ;;when you call or e-mail you talk to his wife Rose i'd talk to him once when i had him machine my intake for burst panel but he doesn't speak english very good so hard to understand..
any help on finding out this guys work before hand would be nice... |
Nu-Tech
All I could find was a map. Is this who you are looking for?
http://411.sandiego.com/Nutech+Engin...221p.home.html |
Re: Nu-Tech
http://411.sandiego.com/Nutech+Engin...221p.home.html Hello Sir, Yes we do owned a machine shop here in Southern California and the name of our shop is Nu-Tech Hi Performance but we go by Nutech Racing for short...We do a lot of customize work. If you have anything in mind that needs to be done just ask me if we could do it for you. WE ALSO OFFER CUSTOMIZE MACHINING : ***BLOWER INTAKE MANIFOLD O-RING GROOVING (TOP).*** ***BACKFIRE VALVE INSTALLATION.*** ***BLOWER ,INTAKE MANIFOLD /WELDING*** ***FIXED THREAD(LOOSE THREAD)(BROKEN STUD)*** ***FLY-CUT INTAKE MANIFOLD RAILS (BOTH SIDE)*** ***POLISH INTAKES AND BLOWERS*** *CUT PULLEY'S LENGTH INSIZE 1/2 PITCH/ 8.0MM/13.9 MM/14.0 MM* ***CUT BELT IN SIZE 1/2 PITCH ,8.0MM/13.9/14.0MM*** ***REBUILD BLOWERS*** ***MACHINE AND TEFLON ROTORS 6 POINTS*** ***TRIPLE PINNING (ROTORS)*** ***HONE INSIDE CASE*** ***WELD /MACHINE ROTORS*** ***MACHINE /INSTALL BLOWER SIGHT GAUGE /PREASSURE RELIEF VALVE*** ***HARD ANODIZING INSIDE BLOWER /REAR -FRONT BEARING PLATE /ROTORS*** ***WE CUSTOMIZE CENTER TO CENTER DUAL CARB SCOOP *** ***FABRICATE/CUSTUMIZE AFTER MARKET CRANK HUB *** ***BLACK ANODIZING DRIVE KITS*** ***CONVERTS AFTER MARKET MANIFOLD INSTALL E.F.I.*** ***FABRICATE ODD HARD TO FIND PARTS *** ***FABRICATE SPACER ODD SIZE *** ***PREP AND CHROME CARBURATOR*** ***FABRICATE LINKAGE SHAFT 10-32 L/R HEIM END*** ***MACHINE /INSTALL INJECTOR NOZZLE BODY IN PORT/ HAT*** Thanks, Rose |
You got more courage than me, before you send it off to an unknown company, i'd check with RBS, they are a well known and respected comp.
JMO Zip. http://rbssuperchargers.com/ |
| All times are GMT -8. The time now is 08:09 AM. |
