-   -   BBC Compression (https://www.racingjunk.com/forums/showthread.php?t=22928)
supergass 01-28-2009 03:54 PM
BBC Compression
I have 15.03 :1 compression on a 565 now, I want to change heads but if I do not cut them it will have 13.79:1 . Any thoughts on if that would be a mistake not to cut the new heads?? I thought that to cut them puts the spark plug farther behind the dome of the piston as well.
bjuice 01-28-2009 04:00 PM
I personally would want to keep my compression the same..i have PAR 565ci and he will not build a hp 565ci less than 15:1
the compression simply makes the power.
Just curious what kind of heads you putting back on and what you got on there now ?
