-   -   wanted vega parts, hard to find (https://www.racingjunk.com/forums/showthread.php?t=22924)
superstreeter 01-28-2009 10:47 AM
looks like a good place to pick some brains...I`m looking for front lower control arm bushing washers,for a 71 vega,they slip into the end of the bushings, before you stall them into the frame,,mine are worn right out, and GM dont have any left,,a wrecker would probably have something in their yards,,but not a real good time to be routeing through cars, and I have it all apart now,,could use a set of 8,,or at least 6 , to get it all back together..any leads would be helpfull...
zipper06 01-28-2009 09:24 PM
Is this possibly what you are looking for, it's a whole rebuild kit.
http://cgi.ebay.com/ebaymotors/Front...QQcmdZViewItem
superstreeter 01-29-2009 05:11 AM
Yes,,that is the kit,,but it does not come with the washers, you apparently need to use your old washers, and mine are worn right out.
ashtrak 01-29-2009 09:14 AM
Are these to adj your camber/caster on the lower control arms??????
ashtrak 01-29-2009 09:15 AM
you may need to have a machine shop make you some out of flat stock.
superstreeter 01-29-2009 01:07 PM
these fit on the end of the bushings before you slide the assembled lower control arm into place in the frame mounts.
and yes its looking like I may have to get some made, cause no luck finding any yet.
qtrturn1 01-30-2009 10:48 AM
A friend just got a Vega parts car. I'll locate him and see if he would give up his.
