Chassis spec. Question
Is there a minimum tube thickness and wall for structural gussetts and body mount brackets (non structural) on a tube chassis. I'm using all .083 CM for all the main stuff. Some pictures I have seen around look like they use 1". Any contact info for SFI/NHRA? Thanks again!
markadams |
It would probably be a good investment for $35.00 to buy the 25.2 or the 25.4 chassis specs from SFI, that way you won't have any surprises.
JMO Zip. http://www.sfifoundation.com/ |
Right again Zip and thanks for the reply and the link. I have never found that before. Great work!
| All times are GMT -8. The time now is 06:06 PM. |
