-   -   Brake line diameter question (https://www.racingjunk.com/forums/showthread.php?t=22900)
markadams 01-27-2009 02:57 AM
Getting ready to install the brake lines in our tube chassis project. I am looking for suggestions on steel line diameters. I am using a mopar style master cylinder and GM metric calipers on rears and MR2's on front. Should the front line be a larger diameter to the splitter? Larger in the back? I always question which is more important, pressure or volume? Thank you, markadams
mytmouz 01-27-2009 03:09 AM
3/16 tube all the way. The larger the bore, the spongier the pedal feels, generally...
Racefab57 01-27-2009 10:35 AM
Street cars I run 1/4in in the middle(frt to back) and 3/16 to frt wheels and from center of rearend to each rear wheel.Racecars I use 3/16 all over....DR.
