10 inch rim on a 68 chevelle
Can anyone tell me what offset I need to run a 10 inch rim on my 68 chevelle? I have 295-60-15 drag radials and I need a wider rim. Thanks for any help. 68-69 should be the same. Also if I need to I can order my new rearend 3/4" shorter on each side from stock.
I have a pair of 15+10 W/3.5 backspacing and they rub when cornering on the outer well, try a 4. or 4.5
HEY GUYS,I run a 295-60-15 on the back of my 70 el camino and I have 4.5 in backspacing and I have no trouble with clearance.FISHMANJOE
For what its worth, I'm running 295 65 15 on a '70 cutlass and use a 15x10 with 5.5" BS. Tried 5" BS and they rubbed on the outside around turns. Jkaz
| All times are GMT -8. The time now is 03:39 AM. |
