-   -   Vacuum pump (https://www.racingjunk.com/forums/showthread.php?t=22791)
mytmouz 01-14-2009 03:24 PM
Vacuum pump
I am acquiring the parts for a vacuum pump for my sbc. This will be my first one, so I am looking for some advice. I am pretty much down to needing a mandrel. What would be a good one to run? I will need 2 pulleys on mine, one for the alt. and one for the pump. The alt. one is about 4 inches from the balancer now...
tcarda 01-14-2009 04:00 PM
The only one I have used is a BLP mandrel. It works well and I have no complaints.
http://www.blp.com/ProdDisp.asp?CatID=4
zipper06 01-14-2009 04:08 PM
If you're going to a gilmer belt drive type pulley, then good viberations sells the enderle mandrels for about $35.00 each, but you will have to come up with the pulleys and belts. They have 2 different styles of mandrels.
http://www.goodvibesracing.com/Belt_Pump_Drives.htm
mytmouz 01-14-2009 04:09 PM
I'm not sure on the pulley. The pump has a v belt pulley on it, so I was leaning towards a v to keep keep the costs down. Opinions?
zipper06 01-14-2009 04:50 PM
If you can live with a 5.450 dia crank pulley you can buy this set cheap. I realize you don't need the water pump pulley, but the whole package is cheap.
http://cgi.ebay.com/ebaymotors/Reduc...Q5fAccessories
mytmouz 01-14-2009 05:08 PM
It's going to need to be a mandrel, I need the alt. pulley about 4 inches from the balancer, thanks for thew link though...
mopar1962 01-17-2009 12:51 PM
With an ol lady that looks like a big toad I could use one of them pumps, heh, Quote..never trust the mothers looks to bear any semblence of what the daughter may look like,marry the mom :lol:
hammertime 01-17-2009 04:24 PM
I've used the star,aerospace and moroso mandrel like the star and moroso better. Star is pricey is why I went moroso this go around.
