-   -   BBC 291 head flow data (https://www.racingjunk.com/forums/showthread.php?t=22678)
jackbn 01-02-2009 05:34 PM
Does anybody have any flow data for the 291 Rect port BBC heads ? I've had these for quite some time and they have had some work done to them (stainless valves 2.25, etc.). Am going to put these on a little 396 that I'm putting together for my 68 Camaro. Any help would be appreciated.
ashtrak 01-03-2009 02:44 AM
Go to a place called MORTEC. type it in google they have what you need. Hope this helps
jackbn 01-03-2009 05:35 AM
I've been to MORTEC many of times but have never seen anywhere that they list flow data on heads. I've also Googled many different ways and once again have never seen any flow data on 3964291 heads (either stock or ported). Thanks for your response though.
zipper06 01-03-2009 06:44 AM
Here you go jackbn, if it's not here it don't exist, stock, ported, big valevs little valves, you will need the casting #'s not the 291 #..
http://users.erols.com/srweiss/tablehdc.htm#Chevy
jackbn 01-06-2009 08:27 AM
I looked in that site and didn't find anything the 3964291 casting. Found a BBC rect port but that's about it.
