-   -   tall deck bbc help (https://www.racingjunk.com/forums/showthread.php?t=22653)
harley12110 12-31-2008 11:33 AM
tall deck bbc help
i am switchin to a 10.2 deck 598 i have dart 345 heads (i believe are to small?.) my questions are do i need a different intake ....i think the dist is different anythin else u can think of
hotrodharley 12-31-2008 12:26 PM
what block are you using?as to intake you will need a intake for tall deck bbc OR if already have a intake for std. deck bbc then you can use it by using intake spacers.the dist also needs to be for tall deck or one with adjustable collar..on lifters they need to be .300 taller on my dart block[10.20deck]according again to what block you are using.check your cam location..on the dart big M block[as i have]they are in stock location but i've heard of some block having cam raised.if a dart[as i have]then you use std gear drive or timing chain or belt drive for any bbc mark iv's..
hammertime 12-31-2008 12:40 PM
Re: tall deck bbc help
You can use the 9.8 deck intake with the spacers but I would sell the 9.8 and buy a 10.2 intake them spacers are a pain, 2 sets of intake gaskets and then they tend to leak a lot. A slip collar dist is all you will need for dist. Different lifters like mentioned above also. I will agree Dart 345's are small for a 598.
harley12110 12-31-2008 01:28 PM
thanks for the help the block is a bowtie.......any ideas on a good intake for this combo....should i try to sell the 345's or can they be made to work?....
michael1 12-31-2008 03:43 PM
The tall deck intake should accept your distributor because they are recessed for that reason. I have a Dart tall deck intake and it is recessed and Dart told me I could use the same distributor.
tcarda 12-31-2008 05:20 PM
If you are looking to get rid of the bowtie block, I know a guy who might be interested in it.
hammertime 12-31-2008 10:02 PM
Would like to hear more info on what you plan to do with it, car , other parts for engine, cam, carb ? Can give ya more info after this.
harley12110 01-01-2009 07:03 AM
lets see cam is not purchased yet open to ideas.....heads are out of the of dart 345 block is a bowtie tall deck ..crank is lunati pro mod 4.500 stroke.. rods are eagle 6.800 pistons are je 4.600 bore this motor was a shfiroff 598 built in 03 and hurt a rod in 06 then set in a buddys garage til igot it last year he has the cam that was in it ...it came from shafiroff with dart 360 heads which he kept..for his 632 t is going in my 215wb four link dragster.....if it builds enough steam i will run the top dragster series at lebanon valley and epping nh if not i will just bracket race it ....
hammertime 01-01-2009 10:16 AM
OK can help ya out here, Erson Cam 420-116 Grind, This is a Reher Morrsion Hot Rod Series cam, 806/765 284/298 @ 50 112 Cl 7/4 Swap Cam. This cam is used by a lot of motor shops and makes good hp. The heads will hold you back for sure on this size CI motor, they would work better on 496-540 CI. They will work but not as good as others. I would assume with them heads and if you get compression 14.5-15:1, a sniper intake, on alky it'll make 950-960HP honest. A good head on it such as bb3x's it'd make 1050-1075. If your car is fairly light 1900ish it'll go 7.5's or so.
michael1 01-01-2009 01:03 PM
harley12110, you have a pm
