msd front drive distributor bbc comp belt drive??
Has anyone ever used a front mount distributor with a comp belt drive? If so what did u have to modify? Thanx :D
The Comp drive isn't set up for a front drive dist. You'll have to make an adaptor that will bolt to the front of the cam that you can in turn bolt the drive pulley too.
Mark |
| All times are GMT -8. The time now is 06:40 AM. |
