shock ?..KONI SPA1 FRONT SHOCKS
Anyone useing these? And what do you think of them?... i have an s10 im thinking of useing these shocks on. Its a back half car with ladder bar.
I now have comp engineering adjustables but i took them out .. and was compressing and extending them..by hand.. at the same adjustment they feel very different..in compression and rebound. I had issue last year where the front end after the wheels came off the ground... it did not want to settle down. But tighting up rebound on these shocks did help. I also just recently added front suspension travel limiters to keep the front wheels from hanging and bottoming out the shock. I also found rear non adjustable shock was leaking oil and after weighing the car the rear spring rate was too low. So i have new Double Adjustable Vari shocks in the rear and went from 110 spring to 130 spring. thanks in advance Keith |
| All times are GMT -8. The time now is 10:23 PM. |
