-   -   Malibu v6 to v8 swap (https://www.racingjunk.com/forums/showthread.php?t=22472)
blackrat454 12-11-2008 08:26 AM
Hi guys. Got a new Malibu wagon project. What is involved swapping the 6 for a small block? I assume the trans crossmember. However I am unsure about motor mounts. Are the frame mounts different like the Nova's were?
jmarksdragster 12-11-2008 03:21 PM
Crossmember is the same, you just need the frame brackets.
BigKid777 04-07-2009 05:37 PM
Crossmember is the same and v-8 stock style or after market motor mounts can be bolted in a set of existing holes forward of the holes for the v-6 already supplied by the factory.
BigKid777 04-07-2009 05:40 PM
Oh, you will only be using 3 bolts per mount instead of the four as moving the mount forward extends one corner past the front edge of cross member.
slowmotion 04-07-2009 06:29 PM
http://www.maliburacing.com/
