-   -   Dominator overflow (https://www.racingjunk.com/forums/showthread.php?t=22423)
mk5150 12-03-2008 06:47 AM
Dominator overflow
Needle and seat stuck hard after burnout, in a S/C red. Why? what's the solution?
jmarksdragster 12-03-2008 10:00 AM
You can try running it with the pump turned off, run it out of fuel. Turn it back on and see if it will flush out any debris. Otherwise take them out and clean or replace. A bad float will do it as well.
dparker 12-04-2008 01:24 PM
stuck open or closed?
dparker 12-04-2008 01:27 PM
If their stuck open it can be the regulator not holding pressure. Are you runnng 7.5 or less fuel pressure.
