750 hp blower carbs on a non-blown engine
I have 2 new 750 hp carbs that was purchaced for a blower application, sold the blower and still have the carbs. What do I need to do to run them as a pair on a 468. I think metering block has a vac. port on it to run to the blower for the power valve's. I plan to plug the power valve's. What else do I need to do?????
If you block the power valves you'll need to jet up 8 to 10 sizes.
The main difference is that the blower carbs, have boost referenced power valves. Just plug that off, and tune it like you would oterwise, and they should work well.
Frank |
| All times are GMT -8. The time now is 06:29 PM. |
