HOW MUCH HORSEPOWER?
I KNOW THIS IS SOMEWHAT OF A OPEN ENDED QUESTION BUT I AM GOING TO ASK ANYWAY..
i have a 71 nova backhalf car with a smith-racecraft tubular front end car weighs 2925 loaded,th400 right now, and a 4.30 gear..does anyone know approx how much hp it would take to get this thing into the 8.60-8.80 range?. or is there a site that you can offer up info and get a approx number.. thanx for any input |
A moroso slide calculater is a very good guide.
Go to this website and you can plug in the numbers you want to acheive it will tell you how much HP it will take. Use the HP calculator part.
http://www.1bad69.com/calc.htm |
My drag software says that 900 hp and 830 foot pounds, such as the Ohio Crankshaft Super 620 would put you at 8.804 in typical weather conditions.
thanks. this is just what i was looking for..appreciate the help
i dont know tire size but to spin your car 155 mph which is about 8.7ish then with no converter slippage motor will be spinning about 7500 rpms with a 30 inch tire...something to keep in mind
Yeh, but who runs a 30 inch tire on a 8.70 car. Its only 6800 rpm with a 33 tire.
| All times are GMT -8. The time now is 10:26 PM. |
