carb adjustment
what is the best way to adjust two carbs on a blower motor?
if they are not blower carbs to begin with you will need to send them off to BDS.Mert Littlfield or someone like that and have them blueprinted for a roots blower..
if they are blower carbs i would adjust like any other carb, which will include plug readings etc... i personally prefer EGT Pyrometers for blower applications..due to the amount of air moved thru the blower...this is a sure fire way to see how lean or fat you are, without having to WOT ,killing it and checking plugs etc... This is how i had all my blown motors set up ..alcohol and gas. inj and carb Brian |
need more info on your set up to help you!
| All times are GMT -8. The time now is 12:19 AM. |
