-   -   cooling in the pits (https://www.racingjunk.com/forums/showthread.php?t=22367)
superstreeter 11-27-2008 03:38 PM
cooling in the pits
anyone have a good way of cooling a trans in the pits? running a glide and once I start getting into the later rounds, its getting harder to keep the temp down, any McGuyver setups out there?
hammertime 11-27-2008 03:42 PM
A good cooler with a fan helps in the late rounds, but you must start it a few times to get the hot fluid out of the converter. Next thing you can get under it with a water sprayer and spray the pan and converter down it helps a ton.
Tod74 11-27-2008 04:30 PM
You could do like I do and avoid the later rounds.
kwkracing 11-27-2008 04:31 PM
a electric leaf blower! Plug it in your generator and point where the dust shield was!
bjuice 11-27-2008 05:22 PM
i hope you dont have the tranny lines Looped..If so this is One Big problem for over heating..outside what the others said..you may want to try some Hydraulic Fluid they say it runs cooler.
just out of curiosity you wouldn't be running to loose of a conveter would you ?...running a looser converter than what you need will also make that tranny heat up more......
just replaced a buddy of mine tranny ( 350 turbo ) for running to soft of a converter on the street..took his tranny right out..
john858 11-27-2008 05:28 PM
i run synthetic fluid works great imo,but like tod said this past year i just avoided the later rounds :lol:
sg1586 11-27-2008 06:03 PM
This works better than spraying water under your car that could be dripping under your back tires :shock: ..
I also run Hydra/tranz tractor fluid that works great....
http://i126.photobucket.com/albums/p...0Image0012.jpg
hammertime 11-27-2008 06:21 PM
Normally is gone at the hit of the spray if its really hot :lol:
I've sprayed mine several times and never had a issue though
sg1586 11-27-2008 06:35 PM
With all the new stuff out there as far as radiators etc how many guys at the track do you see spraying there radiator??? Not many
lanham 11-27-2008 06:35 PM
X2 on the leaf blower.I also use the universal hydraulic tractor and transmission fluid.Doesnt really matter what brand of hydraulic fluid just as long as it is universal tractor fluid.
