witch is the better one msd6al or 7al-3
would like some input on this . thank for the help
talgregory 8) |
Better for what application?
7 al 3 has all the bells and whistles..If it is a race car(drag racing) and you elect to use the 6al, and you want to use an electric shifter, a two step for the leave etc...then you will have to buy the 6AL Box,+ two step+ rpm switch+ whatever else you decide you need...the cost of all that mumbo jumbo will add up fast. With the 7AL-3 you already have all that crap built into the box...not to mention built in start retard ....much easier and probably cheaper.Definitely more simple wire up..It's a Pretty cool box .A friend of mine had some trouble with his but you will get that with any product I suppose....If it is a street car only with moderate compression the 6AL is a good box. |
I have the 6 al right know i use it drag racing but what is the pro and con of the 7al-3 does 7al-3 have hotter fire than the 6al . dose the 7al -3 have very many thing go wrong with it ? i am thinking about upgrading
thank for the help talgregroy 8) |
7AL3 is 10x the box the 6al is. 7al3 has everything built in it, Shift, Retards, High Side, Launch, Burnout, everything you need is there without purchasing any other boxes.
6al BOX= $ 226
3 STEP RETARD= $226.00 rpm SWITCH FOR SHIFTER = $100 3 STEP REV LIMITER= $80 TOTAL $632 7AL-3 = $ 645 And with the 7AL-3 you get Four built-in timing retard modules plus the start retard...vs the 3 retard modules in the above example Plus the 7AL-3 has more spark energy. |
and also a start retard
Digital 6.
Originally Posted by jmarksdragster
Digital 6.
What is the benefit of the digital 6 or 7? Do you program the timing curve or what?
| All times are GMT -8. The time now is 09:35 PM. |
