-   -   CARBURATION (https://www.racingjunk.com/forums/showthread.php?t=22281)
JEFF69Z28 11-17-2008 03:26 AM
CARBURATION
OVER THE WINTER IM GOING TO REBULD THE TOP HALF OFF MY MOTOR(406CID CHEVY) USEING AFR 210/65CC ELIMINATOR HEADS COMPITION PORTED/ SUPER VICTOR JR INTAKE AND A COMP.CAM SOLID ROLLER WITH 1.6 RATIO ROCKER ARMS.260/264 DURATION @50, 678/688 LIFT.BOTTOM OF MOTOR IS 4340 CRANK,6"H-BEAM RODS,JE FLAT TOP PISTONS,IM GUESSING MY COMPRESSION WILL BE ABOUT 11.25 TO 11.75 TO 1.CAN I STILL USE MY 750 HOLLEY OR WILL I HAVE TO GO UP IN SIZE,IF SO WHAT SIZE WOULD WORK. :?:
jmarksdragster 11-17-2008 06:29 AM
You don't have to go up, but a 1050 or 1000HP would be worth about .010-.015 in ET. You have to decide if the money spent is worth the gain for you.
dparker 11-17-2008 01:23 PM
Sounds like you have some pretty good parts. I think you could bump the compression up. Get a good carb and fly...
hammertime 11-17-2008 01:48 PM
I think a good 950 would be a need with the added upgrades.
Like mentioned above some compression would wake it up.
JEFF69Z28 11-18-2008 05:03 AM
SHOULD I HAVE THE HEADS MILLED TO GET 12.5 OR SO COMPRESSION THAT WOULD BE CHEAPER THAN BUYING NEW PISTONS CORRECT?
hammertime 11-18-2008 06:44 AM
Yes this would be the cheapest way to go, just make sure you have plenty of piston to valve clerance.
