My next possible project
http://i32.photobucket.com/albums/d1...d/100_0123.jpg
I am in the process of acquiring this car. Its intended purpose will be a conversion to an IHRA crate motor stock class car. The old body is not in terrible shape. Another toy to keep my old Chevy II company in the garage. Apparently this program doesn't like me. I have never been able to post an image to this site, just disregard this whole post, this is just frustrating, |
Yeah,OK
Huh, real interesting. Why can you do that? And apparently I can't???
Trust me, I've followed all the directions for posting picturs, for some reason, this site will not let me post anything to the forum. |
Upload it to your photo bucket, once it shows in your album, put the mouse on the box that says" img code" and left click once...a yellow box will pop up that will say "copied" then when you type your racing junk post, just right click the mouse and hit paste.
I can see your mistake just looking at your post.... When using the image post thing, there has to be a [img] at the begining and a [/img] at the end. with the http// part in between them. |
on this one from your post
[img=http://img33.picoodle.com/img/img33/3/11/16/oldewalnut/t_79Firebirdm_7f93a91.jpg][/url]][/IMG] notice that the first [img] is missing the ] after the [img also don't use the url thing from photo bucket use the one that says [img] code which is the bottom one under your pic[/img] on the example below I purposely put a period in the img code box between the M and the G so the pic would not show so you can see what it looks like when you put it in a post. [IM.G]http://i237.phototucket.com/albums/ff253/Tod74/100_0123.jpg[/IM.G] If you are using the[img]thing at the top of the message body where you type your message, you have to make sure you have [/img] with the back slash at the end and do not erase the [] on either side. that's what you did in your first post...you put the photo address between the first [img and the ] look close you will see what I'm talking about. |
Well OK
I have come to the conclusion that I am too ignorant to grasp this. I have tried doing exactly what you said Tod. No picture, only goop on the screen. I even went back and reread the file on posting images, tried to do exactly what was described, same thing, no image.
I would like to believe I can read AND follow simple instructions but on this site , UH-UH, I have no luck. I get the same thing when I try to post a quote. This is the only site I have not been able to post images to. Like I said, something about this site doesn't like me. |
I always like those cars. Are you going to paint it black with the gold bird? :D
bird
We project iit to fit in H/CM with the 330 Hp (340 HP refactored) crate motor. The car will have to weigh 3400 lbs to fit the class minimum of 9.50. Our index(s) are 12.00/7.80, for the 1/4 & 1/8, respectively. Going to be a bear, trying to refurb my Nova and get this one off the ground as well! Thanks to Tod74 for posting the picture. |
| All times are GMT -8. The time now is 02:00 PM. |
