-   -   77 pontiac 400 engine (https://www.racingjunk.com/forums/showthread.php?t=22216)
tetreau 11-09-2008 05:21 AM
Hello, I'm trying to identify an old engine I pulled from a 77 Catalina. It's supposed to be a 400. The #'s on by the front water inlet are 406978.
Chip Tatroe
Owner/Operator
57 Chevy Wheelstander
Truly American Enterprises
www.trulyamericanenterprises.us[/url][/code]
itsabird 11-09-2008 05:45 AM
are there any letters with that number?
tetreau 11-09-2008 06:12 AM
There is a YA, which means auto trans.
The # by the dist. is 86133, and the date stamp is I77 = Sept 1977.
us7race 11-09-2008 07:14 AM
I thought on Pontiac Motors on the passanger sie of the block they has the Cubic Inch cast into the block? Above where the fuel pump is on a SBC...
I done some quick research and here is a list of sites...
I still did not find your numbers..so are you sure you are looking in the proper location for the numbers?
http://www.teufert.net/identify/identify.htm
http://www.pontiacstreetperformance....p/blockID.html
http://www.yearone.com/updatedsingle...ontengid1.html
http://www.pontiacpower.net/castnum01.html
itsabird 11-09-2008 08:29 AM
good work us7, i ran pontiac back in the day, that number shows up in nothing i have. will talk to some old pals that ran them also.
poncholvr 11-11-2008 11:18 PM
numbers are on the block passenger side of the timing cover,and at the distributor in the rear, they will say the block, if its not cast in the block on the bottom by the motor mounts
im guessing the numbers you have by the water neck are the intake manifold numbers
type in pontiac block numbers and do a search its not hard there a re a few guys out there
but look for those numbers, and head numbers,and intake numbers
and we can find them out on here for fun
www.pontiacpower.net here is a good page
