-   -   exhaust backfire (https://www.racingjunk.com/forums/showthread.php?t=22210)
nova77 11-08-2008 12:16 PM
exhaust backfire
i need some clues here--- my car started backfiring out of the exhaust,
whats up with that ???
fla1976 11-08-2008 01:14 PM
Backfire
Normally it is an indication of a burnt exhaust valve. A compression check can confirm easily.
lively 11-08-2008 01:52 PM
is it backfiring on acceleration or when your letting off??more info??? LIVELY
bjuice 11-08-2008 01:59 PM
cracks (leaks) in the exhaust system can also cause this upon deceleration.. (maybe lively was getting to this)..check your exhuast from the headers back ..
imo :D
nova77 11-09-2008 01:05 PM
thanks for all the help !!!!
it only backfires when you let off the gas.
the only changes that were done was i installed a new set of headers. everything else is the same. it only seems to be #5 that it backfires from.
I pulled the plug and looks like it has not fired, it is real clean.
FullTimeRacing 11-09-2008 01:07 PM
might have crack the plug during removal or intalation
FullTimeRacing 11-09-2008 01:08 PM
disregard my last post
nova77 11-09-2008 03:00 PM
thank you everyone--- i found it !!!!
when I welded the header and grinded the welds we goy alittle to thin in one spot. Fixed it and ready to go.
