-   -   piston to head clearance (https://www.racingjunk.com/forums/showthread.php?t=22196)
taps 11-06-2008 03:12 PM
on a steel rod big block chevy what is the minimum piston to head clearance?
ARUSSELL 11-07-2008 08:11 AM
We, JE, Reccomend min .040 between the piston and head
curtisreed 11-07-2008 08:33 AM
Wouldn't you need to know how big the bore is to give a solid answer on this? Piston rock could come into play depending on just how big of and engine he is building right?
Curtis
taps 11-08-2008 09:22 AM
engine is 468 4.310 bore.
zipper06 11-08-2008 09:53 AM
I think doorracer is right if you run a good forged piston you need atleast .005/.006 clearance and you have to consider the rock of the piston. JE's recommendation of .040 is a safe one with "0" deck ht., the last 468" i put together i used .039 Felpro gaskets and it has 2618 flattop forged pistons with .0065 clearance. I put that much clearance in the motor because the owner wanted to be able to spray a 250 shot of nitrous. It's a pump gas motor and runs 6.80's 1/8 mi. no spray in a 3700lb street car.
