350sbc how much hp????
i have a 350sbc std bore and storke
stock bottom end with 9.3:1 pistons hydraulic flatt tappet cam with .488 lift 234 duration at .050 and 292 advertised duration 462 double hump heads 1.94/1.50 valves(mild port work) single plane intake holley 750 double pumper how much horserpower do you think it should have?? i did desktop dyno and got 390hp and 415tq i thought that was a lil high but could be wrong |
I think that's high also and i also think there's a couple things that you could do to improve. First the single plane manifold is really bad on bottom end, and 2nd the carb is too big for the cam and heads that you have especially for the street.
JMO Zip. |
i agree with zip, hp sounds on the high side, duel plane and 650 max cfm carb may work better with your combo.
the motor will be used for dragracing
and the carb im not to sure on the size the choke horn was milled off before i got it and couldnt get the number off it to look it up |
With the duel plane and the smaller carb you are almost building a 350/ 350hp engine
My thoughts would be cut the heads bout .030 and use the .017 head gasket for more comp. air gap intake and 650 carb or if it is footbrake car mabe a 750 vac. also if you could get Vortec heads that alone is worth 20 or so horses My Opinion. Later J. Smith 4621 racing
it is a footbrake truck
how much would i gain by shaving the heads down(compression and power)?? |
also what size header should i go with?
i was gona go with 1 5/8" with 3" collector we have to make the headers cause no one makes headers for a sbc in a ranger lol |
If your having to make your headers go big, the 1 5/8's X 3 will be fine. You''ll more than likley end up going bigger with the motor anyways since your racing it so why not have the bigger better headers already. Just makes sence.
Anytime you reduce combustin chamber volume and squish you will see a increase in torque and horsepower, now how much is debatable. It really depends on the cam - high lift / long duration cams love compression, just make sure you check piston to valve clearance afterwards. Goodluck>Cp |
what size converter would you guys suggest
i was thinkin around 3000 |
| All times are GMT -8. The time now is 04:49 AM. |
