-   -   Beadlocks (https://www.racingjunk.com/forums/showthread.php?t=22180)
ARUSSELL 11-04-2008 09:31 AM
Beadlocks
Any thoughts on running a beadlock rim on a street car? The have 2 sets of 15x15 and one is beadlock the other is not.
russ67chevelle 11-05-2008 04:12 PM
depends on a lot.weight of vehicle,torque applied are main factors to start somewhere...ive seen cars run sevens in quarter with simple tire screws.i run mid eights @ 160 mph with screws on et streets...so what are the specifics on your application?
ARUSSELL 11-06-2008 06:56 AM
I know by all means a screw will be enough, but just wondering if there is any disadvantage with a beadlock on a street car. I have a 3400 lb 70 chevelle engine makes 650 ft/lb.
curtisreed 11-06-2008 09:37 AM
I've been thinking about this since you posted and I can't come with anything that would prevent me from running them. If you are worrying about the side loading around corners I would think they would never see anything as bad as what rock crawlers do to them.
Curtis
