Alcohol plug gap
What is the gap that you use for your alcohol n/a motor
If the gap moves what does that mean thanks for your help |
Re: Alcohol plug gap
If the gap moves what does that mean thanks for your help I use .035 gap If your gap is moving, have you tried to index them ? If they are closing up you may need to look into a different plug. |
Thank you hammertime
Thank you hammertime, for your help. I will use that when I change the plugs.
Thanks again |
Re: Thank you hammertime
Thanks again |
I set the gap .030-.035 and ya what he said about the gap moving, thats not good!
| All times are GMT -8. The time now is 07:24 PM. |
