Another dumb question
I know this is going to sound dumb but I believe a dumb question is one that you don't ask. If you go to my racespace and look at the engine that I have as my default there are to lines on the intake (one on each side) that run from the front to the back of the intake......what are these lines for. I just recently got this engine (421sbc) and I have seen them on engines before but have never known what they were for. Thanks in advance for the help.
Chris |
without seeing the pictures it sounds like it is for the water to flow through
Sorry you can't see the pic. If I had an email I could send it to and have posted, that would be appreciated. I am just computer illiterate (sp?)
Thanks Chris |
Lines running rear to front or center to front are to make cooling a little more even. Not too critical in a drag motor, but may help a little.
I've found they help get air out of the system faster also. Especially with a lot of drag radiators being lower than the motor.
Curtis |
Curtis |
Vega
Curtis Yes those Lines are more of a Transfer cooling Line,from front to rear on the Intake. Later G 8) |
Re: Vega
Curtis Yes those Lines are more of a Transfer cooling Line,from front to rear on the Intake. Later G 8) Chris |
| All times are GMT -8. The time now is 03:25 AM. |
