8 or 10 inch rim for 28/11.5 slick.
Hi i was just wondering if i should use a 8 or a 10 inch wide rim using a 28/11.5 slick? What is the advantages of both?
the 10 inch wheel will give you a "wider footprint" this mean more tire will be acutally making contact with the ground...which is a very good thing.
always go with a wider wheel when you can...even the Outlaw 10.5 guy's who must use a 10 inch tire are putting them on 12 inch rims and flattening out the foot print. in your case there would be No advantage i could think of by using the 8 inch rim...go to 12 inch wheel if it will fit under your car. Brian |
If clearance is an issue you will want to use the narrower wheel to pull the sidewall bulge in. Other than that the wider wheel should be the better choice.
| All times are GMT -8. The time now is 01:18 PM. |
