-   -   66 or 68 chevelle (https://www.racingjunk.com/forums/showthread.php?t=22114)
michael1 10-24-2008 03:41 PM
66 or 68 chevelle
Can anyone tell me which car would work best in the stock suspension class and which one is lighter.The 66 is a hardtop and the 68 is a sedan. I'm going to put all after market upper and lower control arms but the wheel base is different so will one work better than the other. Thanks
zipper06 10-24-2008 05:22 PM
The 66 is definately lighter and smaller, given my rathers, i'd choose the 66.
lively 10-24-2008 05:31 PM
THE 66 FOR SURE
THAT COMES FROM A "FORD" MAN
LIVELY
Tod74 10-24-2008 05:52 PM
I would choose the 66....IF FOR NO OTHER REASON...It is a better looking car in my opinion.
suicidebomb 10-24-2008 06:57 PM
[quote="Tod74"]I would choose the 66....IF FOR NO OTHER REASON...It is a better looking car in my opinion.[/quote
x2jmo
michael1 10-24-2008 10:05 PM
looks like I'm going to build the 68 because it has a shorter wheelbase and they are suppose to hook up better. I have a picture of the car under the show off thread before we stripped it down. The car is a real solid car.The 68 is actually lighter believe it or not because it is a post car according to all the books that I have read.
Tod74 10-25-2008 12:30 AM
Still a cool car.
michael1 10-25-2008 07:52 AM
Thanks Tod
Scooterz 10-25-2008 10:13 AM
Good Choice... I have had a 68 & 69... but they were both street cars. Only major problem was around the rear window molding as they do not drain properly resulting in big time cancer. Personally, I love the lines of the 68/9... even the air-duct vents that say "Astro Ventilation"!! The tail lights on the 68 look better. The 68 was the last year of the dash ignition & last of the wing-windows too. They are neat cars...
hemicop 11-09-2008 02:15 PM
Well, let's see--- your '68 is a post car (therefore stiffer initially) has a shorter WB, less rear overhang ( I think) and you Could run anything from a 6cyl to a BBC.
The '66 is overall smaller, percentage-wise more overhang, less frontal area (although squarer) & can accomodate any engine also.
I weigh each one to be sure, measure the frontal area also, THEN make the decision. This sounds like a racecar project & function usually takes prefernce over form.......
