-   -   Which Spark Plug (https://www.racingjunk.com/forums/showthread.php?t=22104)
bowtie4542001 10-23-2008 03:02 PM
Which Spark Plug
Hey guys, I am needing some advice on selecting a spark plug. I have a 421 SBC on alcohol. The compression is 14:1 I have a MSD 7AL-2 with a baster coil to provide the spark. Not too familiar with alcohol. What plugs would yall recommend. Any help or advice would be greatly appreciated.
Chris
zipper06 10-23-2008 09:16 PM
Which heads? If you have Brodix heads you can go to their website and they have recomendations. I run the NGK plugs which they call for with Track 1's
bowtie4542001 10-23-2008 10:19 PM
They are Pro Comp aluminum heads. Don't know that much about them. 190cc intake runners
2.02 intake 1.60 exhaust SS valves
Also what gap should I start at?
Chris
zipper06 10-23-2008 11:13 PM
I run .030 gap with alcohol.
bowtie4542001 10-24-2008 12:28 AM
Appreicate the help, which NGK plug?
Chris
zipper06 10-24-2008 07:11 AM
NGK-R5671A-9 for alcohol
NGK-R5671A-8 for gas
Depending on the compression you have you should probably index the plugs just to be on the safe side.
bowtie4542001 10-24-2008 10:53 AM
Thanks Zip
bigray 10-26-2008 08:28 PM
when you index them.witch way sould they be facing ?????
nofear57 10-26-2008 08:56 PM
My Enderle Alcohol injected Altered has a 13.5:1 sbc 434 with Brodix 11X heads and I run NGK B9ES plugs gaped at .035 and I run an MSD7AL3 with a Pro Power coil. Very reliable with no issues.
hammertime 10-26-2008 09:08 PM
between 10 and 2
