Weak springs?
Hi,
I have a Crane TR-272/4167-2S-10 cam in my 509. The cam card says: 1967-UP CHEVROLET V-8 396 THRU 454 CU.IN. MODERATE COMP. ONLY, GOOD UPPER R.P.M. TORQUE & H.P., HIGH COMP. RATIO REQUIRED INTAKE @CAM 4167 @VALVE 708 EXHAUST @CAM 4167 @VALVE 708 TIMING OPENS CLOSES ADV DURATION @ .0195 INTAKE 45 BTDC 85 ABDC 310 ° TAPPET LIFT EXHAUST 88 BBDC 48 ATDC 316 @ .050 INTAKE 29 BTDC 63 ABDC 105 °ATDC 272 ° TAPPET LIFT EXHAUST 72 BBDC 26 ATDC 115 °BTDC 278 RECOMMENDED RPM RANGE WITH MATCHING COMPONENTS MINIMUM RPM 4400 MAXIMUM RPM 7800 VALVE FLOAT 8500 So not a street cam, but not a pro-stock cam either. The valve spring recommandation: Crane-99876 LOADS: CLOSED 160 LBS @ 1.968 OR 1 31/32 OPEN 490 LBS @ 1.308 I have installed them on 1.950" which gives 160-180lbs seat pressure new. Few questions. Is this enought as the rpm at finish line is about 7000? Should I upgrade the springs? Spring recommadations for 1.55 size? Heads are with 2.19/1.88 stainless steel valves. I had about 50 runs on new springs and lifters when we took it apart. Springs are now 150-180lbs at the seat. Valve seats and lifters seems to be fine. |
I would make sure the springs are AT LEAST at the specs on the cam card...you could lose the whole motor over a cheap (relatively speaking) part. Any doubt in your mind at all I would get new ones.
Is this a roller cam or flat tappet cam?
Zip. |
http://cranecams.com/index.php?show=...01&lvl=2&prt=5
According to Crane's website, you don't have enough spring. |
Your spring part # should be 99886, not 99876. Big difference. If it were me I would set the heads up with a PAC 1246 spring, but at least get the correct springs. If you are limited to a 1.55 spring, a PAC 1225 would work much better than what you have.
OneBadGMC, that's funny. I got exatly the same camcard from 90's which says exatly same things expect the springs are Crane-99876.
LOADS: CLOSED 160 LBS @ 1.968 OR 1 31/32 OPEN 490 LBS @ 1.308 |
Maybe they figured out that it wasn't enough spring and revised the website and new cam cards?
If you can fit a 1.56" spring, go with a PSI CT1227 http://www.psisprings.com/index.php?...ask=view&id=17 |
This is copied from the original post, very confusing.
1967-UP CHEVROLET V-8 396 THRU 454 CU.IN. MODERATE COMP. ONLY, GOOD UPPER R.P.M. TORQUE & H.P., HIGH COMP. RATIO REQUIRED Moderate comp only, then high comp required? wt? I'd go with the springs recommended from crane they know whats best for their cams, or go with a comparriabled set with them same seat pressure, same installed height and coil bind. Goodluck, Charles |
Yeah your probably right Todd, that didn't even occure to me.
Cp |
| All times are GMT -8. The time now is 09:12 AM. |
