Building a new 540
My new 540 will be going in a '65 Nova tube chassis with ladder bars,Dana 60 w/4.56, tire 33x16.5, turbo 400, 2860lbs with me in it. The motor is Dart block, Brodix BB2x lightly ported and gasket matched, Brodix intake, cam specs 772 int 765 ex dur @ .050 285 int 296 ex with a Ken Jones 1050 Dom. Comp. is 12.8. What do you guys think it will run in the 1/4 ? I'm hoping 9.0s
With tuning right it could easly run 9.50's
JMO Zip. |
Re: Building a new 540
.My camaro (3100lbs) with a 12 to 1 compression 511 ci ran mid 5.90's in 1/8.. which should be in the lower 9.60's in 1/4...
with my new 565ci if i do not run 5.60's in the 1/8 and 9.20 range in 1/4 i will be disapointed. This is what i typed in another post.....i got a little more motor than you but your about 250lbs lighter then me......... so this where i have been and where i think i will go..it will give you a good gauge.. the 9.0's your hoping for may be a little Quick... but i hope you get 8.90's out of her ! |
You for sure can get there if you spray it.
Well right now with an iron headed 477 it runs 9.70s has gone a best of 9.67. Thanks for the responses though. And yes it will be FUN. It will be all motor no spray for me thanks.
i have a 540 dart block 14/1 785 779 288 [email protected] dart 325s 3640lb car runs 970 with 60ft on the rear wheels they are a great torque motor
what MPH you running..also what is your 60 and 330 ? Many oldtimers will tell you time and time again its not really how much motor you got (within reason) but how you lay it down... :D |
bjuice my mph is 135-136. My 60's are usually 1.37-1.38. My 330's are 4.00- 4.05
My nova has a 540 in it with 345 dart heads Gen 6 block and injection 3563.lbs and goes 9.21 at 149.88
i just blew the trans and converter out rebuilt the trans and borrowed a converter from a friend that runs a small block and it goes 6800 behind mine way to loose but here's a short video. from this weekend it went 585 in the 1/8. http://s76.photobucket.com/albums/j4...acing_0001.flv |
| All times are GMT -8. The time now is 10:06 AM. |
