wheel tubs????
ANY PREFERENCE ON WHEEL TUBS OR DOES EVERYONE MAKE THEIR OWN????????? 8)
IT IS THAT TIME FOR MY GASSER AND AM CHECKING THINGS FIRST!! :shock: LIVELY |
Lively, Steel or alum its up to you ! Everybody makes em! I always like the alum, but steel are a little cheaper and you can paint em easier! D.R.
Wheel Tubs
You can make your own or you can go to various sites like Jegs. Belive it or not Jegs has steel or aluminum for about $80.00. Try a web search it worked for me. You might want to check out you tube for pointers. I hope this helps. Best of luck.
I like the steel ones. As stated above, they take paint and you can weld them in. After both are beaded, the steel are much stronger. Dave
We used a set from S&W in a back half kit we purchased from them. They came in a box that you use to lay them out for cutting and had good instructions. I know it is not rocket science putting them in but it was very helpful.
Curtis |
| All times are GMT -8. The time now is 06:07 PM. |
